Adsibob Posted April 15, 2021 Share Posted April 15, 2021 In my quest to hack a bog standard kitchen into something more fancy, instead of having the regular plinth to match the rest of the kitchen, we want it to be brass. The downsides of brass are that it might get scuffed easily when people knock into it with their shoes and I also imagine it's going to be quite expensive as we need about 12m by 10cm of it, although it would be pretty thin as it has to be flexible enough to bend into four right angled curves for the bit that goes around our island. It's structure would just be the plinth that is supplied by the kitchen company. Has anyone sourced such a piece of brass, if so where from? Would an alternative be to paint the plinth with some sort of gold paint. Has anybody done that before. Does it look good, or do I need to powder coat it? Link to comment Share on other sites More sharing options...
tonyshouse Posted April 15, 2021 Share Posted April 15, 2021 Buy a roll of 100mm wide thin brass and glue it on I like route red in draught strips to the bottom edge of plinths and flat floors. consider brass angle for the corners Link to comment Share on other sites More sharing options...
dpmiller Posted April 15, 2021 Share Posted April 15, 2021 Find someone locally that does bar and hotel work, that kinda thing is their bread and butter... 1 Link to comment Share on other sites More sharing options...
tanneja Posted August 27, 2021 Share Posted August 27, 2021 On 15/04/2021 at 01:35, Adsibob said: In my quest to hack a bog standard kitchen into something more fancy, instead of having the regular plinth to match the rest of the kitchen, we want it to be brass. The downsides of brass are that it might get scuffed easily when people knock into it with their shoes and I also imagine it's going to be quite expensive as we need about 12m by 10cm of it, although it would be pretty thin as it has to be flexible enough to bend into four right angled curves for the bit that goes around our island. It's structure would just be the plinth that is supplied by the kitchen company. Has anyone sourced such a piece of brass, if so where from? Would an alternative be to paint the plinth with some sort of gold paint. Has anybody done that before. Does it look good, or do I need to powder coat it? @Adsibob did you go through with this and find an affordable way to do it? Link to comment Share on other sites More sharing options...
Adsibob Posted August 27, 2021 Author Share Posted August 27, 2021 We are getting quotes at the moment. Brass is not particularly expensive, so I’m hoping it will be affordable; will report back soon. 2 Link to comment Share on other sites More sharing options...
tanneja Posted April 6, 2022 Share Posted April 6, 2022 @Adsibob did you get the brass sheets in the end? I came across a company in Liverpool yesterday when on Pinterest, I am thinking plinth and reverse of breakfast bar in brushed brass finish for us Link to comment Share on other sites More sharing options...
TonyT Posted April 6, 2022 Share Posted April 6, 2022 Check out blacksmiths etc for brass sheet mine supplied one to replace a damaged threshold strip on a Victorian front door entrance Link to comment Share on other sites More sharing options...
Adsibob Posted April 6, 2022 Author Share Posted April 6, 2022 2 hours ago, tanneja said: @Adsibob did you get the brass sheets in the end? I came across a company in Liverpool yesterday when on Pinterest, I am thinking plinth and reverse of breakfast bar in brushed brass finish for us The joinery company doing the kitchen is going to show me some samples of “laminate” brass, which I think is mostly fake. Would you mind PMing me the details of your Liverpool supplier? Link to comment Share on other sites More sharing options...
tanneja Posted April 6, 2022 Share Posted April 6, 2022 @Adsibob https://www.ebay.co.uk/str/sheetmetalsales planned to contact them this week for my purposes. I also need balustrades. Link to comment Share on other sites More sharing options...
