eandg Posted April 13, 2021 Posted April 13, 2021 Looking at my quote the difference between the standard radial ducting kit and the premium one is £559. It also includes optional extras for a wall mounted controller (£53) and 5x boost switches (at £30 a pop). Any thoughts on whether paying for the upgrades and extras are worth it?
dpmiller Posted April 14, 2021 Posted April 14, 2021 the expensive ducting is slightly more flexible Do you need a controller or is your unit going to be easily-accessible? Do you require manual boost-request switches?
eandg Posted April 14, 2021 Author Posted April 14, 2021 50 minutes ago, dpmiller said: the expensive ducting is slightly more flexible Do you need a controller or is your unit going to be easily-accessible? Do you require manual boost-request switches? Unit will be in the loft. Not really a problem getting to it. I've no idea what manual boost does it when it'd be required?
joe90 Posted April 14, 2021 Posted April 14, 2021 4 minutes ago, eandg said: I've no idea what manual boost does it when it'd be required? I don’t have any but some here do, for example one in the kitchen will enable you to select boost in case of burnt toast!!! Or one in the bathroom when having a shower instead of waiting fir the humidistat to kick in (if you have one). 1
dpmiller Posted April 14, 2021 Posted April 14, 2021 does the unit have a humidistat? You might need a means to put it into boost mode after a shower or a serious toilet episode. 1
eandg Posted April 14, 2021 Author Posted April 14, 2021 1 hour ago, dpmiller said: does the unit have a humidistat? You might need a means to put it into boost mode after a shower or a serious toilet episode. It has "internal humidity control" if that's the same thing...
Bitpipe Posted April 14, 2021 Posted April 14, 2021 We didn't use manual boost switches but got the sparky to wire up the MVHR to the same trigger (bathroom PIRs / light switches) that activate the hot return pump. Works quite well - the Sentinel Kinetic has a variety of ways to trigger boost electrically as well as it's own internal humidity sensor. It also has a control /display panel that can be wall mounted away from the unit (wired connection) so we have that in the utility and can trigger a manual boost or purge from there. We did look into incorporating the boost for cooker hood but the only way would have been to put a current detecting clamp on the hood feed so we decided to live with it and have never bothered.
phatboy Posted April 26, 2021 Posted April 26, 2021 Assuming it's a Vent Axia unit.... - I got the wired controller with cable new on eBay for £20 - No wired boost switches.... the shower relies on the in-built humidistat, and I hooked up a variable input voltage relay to the cooker extractor motor side, and used one of the volt-free connections on the main unit When I did mine 2 years ago they only did 1 type of pipe (red), which seems to be the premium one now!
Haylingbilly Posted April 28, 2021 Posted April 28, 2021 For some reason I missed all the comments on this - so thank you for all of the input. I am about to order so it is all really helpful Cheers
phatboy Posted April 28, 2021 Posted April 28, 2021 Also I'd recommend getting a silencer for the extract side of the system, before the MHRV unit. I found it quietened down the vents to near silence.... it also provided another convenient flexible joint! 1
