SillyBilly Posted April 8, 2021 Posted April 8, 2021 I am building an extension. Have done the beam and block floor. Plan to have 150mm celotex or similar standing on a 1200 gauge polythene dpm joined to downturned 450mm dpc. I am not installing UFH and am considering a floating floor of glued 22mm t&g panels standing on the PIR or possibly engineered wood flooring. Is that suitable and do I need another dpm over PIR as not pouring screed on it?
Russell griffiths Posted April 8, 2021 Posted April 8, 2021 If you don’t put a screed on top of the insulation how are you going to get your floor flat, I bet the block n beam floor is far from level or flat, also have you first hand experience of a floating floor. All the ones I have seen if you jump up and down in one corner the telly changes Channel all by itself. I personally would rethink this idea, but obviously that’s my opinion.
tonyshouse Posted April 8, 2021 Posted April 8, 2021 I worry about air leakage through the beam and block followed by infiltration into the room, cavity walls also leak. I would have poly on top of insulation, then combined air barrier, vb and dpm, then trap it behind presumed skirtings sealed at doors and corners
SillyBilly Posted June 14, 2021 Author Posted June 14, 2021 Thanks for replies so far. Didn't see them as no email notifcations received. Still thinking about it
Mr Punter Posted June 14, 2021 Posted June 14, 2021 You should have a polythene vapour control layer on top of the insulation. The reason for this is because there is a risk that warm moist air from the house could get through the gaps between the insulation and condense on the beam and block. Quite unlikely but ho-hum.
