DIY_Amateur Posted April 7, 2021 Posted April 7, 2021 Hi - I'm pretty sure the thermostatic head (with capillary sensor) on my UFH manifold is knackered. I can get a replacement and the head will just screw onto the valve body but accessing the current sensor and having room to remove it is going to be a pain. Two questions: 1) The sensor is held in with a grub screw so I assume it's not actually immersed in water inside the manifold (Uponor Vario B, maybe cocooned in a sleeve?) Is that right/likely and if I was able to remove the grub screw and get the sensor out would I need to drain the manifold first? 2) If I really can't get the old sensor out can I attach the sensor directly to the flow side of the manifold with some cable ties and maybe some aluminium tape/insulation - would this work do you think? There are surprisingly few pictures/video of this job so I appreciate any knowledge of what it involves. Thank you
PeterW Posted April 7, 2021 Posted April 7, 2021 Sensor will slide out of its pocket. Just remove the link grub screw and twist it a little to break any potential corrosion. They are dry pockets so no water should escape.
DIY_Amateur Posted April 7, 2021 Author Posted April 7, 2021 Hi Peter- that's very helpful thank you The sensor is pressed against the wall so would need to slide 10cm or so into the wall! I'm tempted to see if I can find a way to carve a hole for it to slide into but if not it plan (2) - any thoughts on whether strapping it to the manifold would work adequately?
PeterW Posted April 7, 2021 Posted April 7, 2021 You’d need to work out how to get the new one in too ..! I do sometimes wonder what installers are thinking when they install these ..!!
Nickfromwales Posted April 7, 2021 Posted April 7, 2021 Drain down and disassemble. Do the job properly
DIY_Amateur Posted April 8, 2021 Author Posted April 8, 2021 Thanks Nick - I went for plan (3) and created a hole in the wall that I could slide the sensor into and remove it, so I've saved having to drain down and hopefully the new part will fix things. Thanks for the advice
ProDave Posted April 8, 2021 Posted April 8, 2021 16 hours ago, PeterW said: You’d need to work out how to get the new one in too ..! I do sometimes wonder what installers are thinking when they install these ..!! Had the same problem with a HW tank and immersion heater, I had to cut a hole in a wall to get the old immersion heater out and a new one in. People just don't think.
