MAB Posted April 3, 2021 Posted April 3, 2021 (edited) Anybody used this or any similar 'Wallrock' wall lining products for use in rooms in older housed with cold exterior walls? The reviews in link below seem good and one of my neighbours has used it recently with good results. Seems a good compromise where installing thicker insulated plasterboard would involve removing/damaging original 'period' features of an older house like skirtings, etc, and much better than the old polystyrene wall lining rolls my dad tried back in the 1970's, which was not very robust with us as kids in the house..... Product description Wallrock Klimatec KV600 Thermal Liner – put simply, ‘The Big Brother of Wallrock Thermal Liner’ is a new and improved thermal lining paper that draws on all of the successes of Erfurt Mav’s Wallrock Thermal Liner, but provides even greater insulation benefits. The most effective place to place any thermal barrier is on the inside of the coldest walls which is why we have developed this product especially for use on the inside of your home. It is especially effective on external walls by which we mean walls that are open to the elements on the other side. When a room has been lined with Wallrock Thermal Liner it separates the cold mass of the wall from the room environment and reduces both the cooling effect of the wall and cold air currents in the room created by the differential temperature zones within a room. Therefore, the maximum amount of heat is available to heat up the room air. Rooms thus become warm and cosy up to 65% more quickly and energy consumption is reduced by up to 35%. Any room will benefit from the use of thermal liner, the biggest benefits however are in older houses with solid wall construction. https://www.gowallpaper.co.uk/erfurt-mav-wallrock-kv600-thermal-liner.html Wallrock Thermal Liner https://www.gowallpaper.co.uk/erfurt-mav-wallrock-thermal-liner.html Wallrock range:- https://www.gowallpaper.co.uk/wallrock-range.html Edited April 3, 2021 by MAB
ProDave Posted April 3, 2021 Posted April 3, 2021 This is a 4mm thick "insulated" lining paper. Don't expect it to make a great deal of difference to the overall heat loss. If only it was that easy.
tonyshouse Posted April 4, 2021 Posted April 4, 2021 Insulation needs to be hundreds of millimetres thick to be compliant with regs, useful for future proofing and to make ant sense sustainability wise.
TryC Posted April 20, 2021 Posted April 20, 2021 On 03/04/2021 at 19:12, MAB said: Anybody used this or any similar 'Wallrock' wall lining products for use in rooms in older housed with cold exterior walls? The reviews in link below seem good and one of my neighbours has used it recently with good results. Seems a good compromise where installing thicker insulated plasterboard would involve removing/damaging original 'period' features of an older house like skirtings, etc, and much better than the old polystyrene wall lining rolls my dad tried back in the 1970's, which was not very robust with us as kids in the house..... Product description Wallrock Klimatec KV600 Thermal Liner – put simply, ‘The Big Brother of Wallrock Thermal Liner’ is a new and improved thermal lining paper that draws on all of the successes of Erfurt Mav’s Wallrock Thermal Liner, but provides even greater insulation benefits. The most effective place to place any thermal barrier is on the inside of the coldest walls which is why we have developed this product especially for use on the inside of your home. It is especially effective on external walls by which we mean walls that are open to the elements on the other side. When a room has been lined with Wallrock Thermal Liner it separates the cold mass of the wall from the room environment and reduces both the cooling effect of the wall and cold air currents in the room created by the differential temperature zones within a room. Therefore, the maximum amount of heat is available to heat up the room air. Rooms thus become warm and cosy up to 65% more quickly and energy consumption is reduced by up to 35%. Any room will benefit from the use of thermal liner, the biggest benefits however are in older houses with solid wall construction. https://www.gowallpaper.co.uk/erfurt-mav-wallrock-kv600-thermal-liner.html Wallrock Thermal Liner https://www.gowallpaper.co.uk/erfurt-mav-wallrock-thermal-liner.html Wallrock range:- https://www.gowallpaper.co.uk/wallrock-range.html Hi MAB, May I ask if you ending going down this route with KV600?
MAB Posted April 26, 2021 Author Posted April 26, 2021 (edited) On 20/04/2021 at 22:10, TryC said: Hi MAB, May I ask if you ending going down this route with KV600? Not yet.....my neighbour who has a similar 'period' house to mine, which would be difficult to insulate to modern Building Regs requirements without ruining internal or external 'period features,' is currently giving it a try and is impressed with the results so far....but he really needs to go through a full winter season to confirm that it at least improves comfort levels of the rooms with 'cold' solid brick external walls. Edited April 26, 2021 by MAB
TryC Posted April 28, 2021 Posted April 28, 2021 On 26/04/2021 at 18:44, MAB said: Not yet.....my neighbour who has a similar 'period' house to mine, which would be difficult to insulate to modern Building Regs requirements without ruining internal or external 'period features,' is currently giving it a try and is impressed with the results so far....but he really needs to go through a full winter season to confirm that it at least improves comfort levels of the rooms with 'cold' solid brick external walls. ah , i see. we're getting ready to do ours at some point!
MAB Posted April 29, 2021 Author Posted April 29, 2021 Keep us informed if possible, its on my list of things to do/try......it can only be better than the existing 'cold' external solid walls and the reviews seem good, as long as you don't expect to match the levels achieved with 50+mm of Celotex insulation!
TryC Posted April 29, 2021 Posted April 29, 2021 1 hour ago, MAB said: Keep us informed if possible, its on my list of things to do/try......it can only be better than the existing 'cold' external solid walls and the reviews seem good, as long as you don't expect to match the levels achieved with 50+mm of Celotex insulation! will do! haha, no I don't but it is better than nothing! we have stone walls and apparently, it is a bugger to drill and insulate or the tradepeople actually refuse to do it because it is too much efforts. I previously used the red label for one room when I was a student and couldn't afford wall rock - not that it I can now but I'm not looking to keep doing it so thought this time I have to try wall rock! ha ha 1
