gravelrash Posted March 12, 2021 Posted March 12, 2021 masonry walls, 200mm cavity with 3m opening and deciding on split lintel for inner cavity wall... which would be most thermally efficient, concrete or steel box? anyone with experience?
Moonshine Posted March 12, 2021 Posted March 12, 2021 (edited) 35 minutes ago, PeterW said: Insulated steel box would be preferable. Edit: ignore me. Edited March 12, 2021 by Moonshine
joe90 Posted March 12, 2021 Posted March 12, 2021 For our bifolds I used separate concrete lintels for each skin and have a 200mm cavity. Because ours is brick built i cut bricks into slips and stuck them on the outside to match.
Oz07 Posted March 12, 2021 Posted March 12, 2021 1 hour ago, joe90 said: For our bifolds I used separate concrete lintels for each skin and have a 200mm cavity. Because ours is brick built i cut bricks into slips and stuck them on the outside to match. What length were these?
joe90 Posted March 12, 2021 Posted March 12, 2021 58 minutes ago, Oz07 said: What length were these? 3meters 1
gravelrash Posted March 13, 2021 Author Posted March 13, 2021 Joe90# Did you access the various lintels for u values before deciding on concrete?
