I’m putting in noggins ready for the plasterboard ceiling .
What should I do where sloped plasterboard meets horizontal ceiling ?
A noggin at the top ( and bottom ) for the slope . Another noggin at the top for the ceiling ? . Just seems wasteful and awkward - or is it simply the way ?
Edited by pocster
2 minutes ago, Onoff said:
The edges of each board need support imho.
Yeah that’s what I thought .
I’ll use more noggins and put the ceiling pb up first . Then at least the sloped pb will offer some support at the joint ( ceiling to slope ) . Probably over thinking it as it avoids doing the work ?
13 minutes ago, nod said:
15 mil and above don’t need the edges to be supported Even at 600 mil
Wasn't there a thread about this very issue a little while ago? Tbh I thought it had been said they needed support...
Do you just tape the joint then?
3 minutes ago, Mr Punter said:
Use 15mm.
BM said 12.5 . It’s on-site so using it ?
For reference the water resistant pb on bathroom / ensuite ceiling is also 12.5
3 hours ago, pocster said:
Pb for ceiling is 12.5mm
Collated screws 45mm
Will support all ends !
The PB on the.ceiling should always be 15 mil on 600 centers
 No 15 mil will carry over 600
Nearly all trusses are counter battened with 75x25 at 600
My bathroom walls and ceiling are 12.5mm moisture resistant on 400mm centres. Will it fall down? ?
The upstairs 4 rooms in the dormer are 9.5mm pb on walls AND ceiling. The proverbial plasterboard tent.
First almost whole sheet up . Will add noggins to ends . Cut it to short ! Typical , I always think things are longer than they actually are !!
1 hour ago, pocster said:
I shall leave for him to complain at ?
And charge more to do "remedials" before he starts!
I think that’s usual for when the plasterer visits me
I see you've bought a broom at last!
