Hi
I really need to get this done sorted for the solar. Anything over 3.68 is diverted to the solar immersion.
Can anyone advise what info I should be putting onto this chart. I am presuming the details I should be recording is the inverter, so the Growatt 3600MTL-S?
Thanks
Well, no one seems to have replied, so this is what I'd put, assuming youi have the 3.6kW Growatt inverter..
Growatt, yesterday ish,1, Growatt3600MTLS2018, 3.6kW, 1.
Sory missed this first time around.
Look in the instruction manual for the inverter.  there should be a G98 conformance certificate from the manufacturer and you want the details from that, or just send a copy of that certificate.
If you don't have one, contact the supplier and ask for the manufacturers G98 compliance certificate.
Our DNO got a bit shirty because my inverter had "4000" in it's part number and they did not believe it was limited to 3.68kW until I forwarded the manufacturers declaration to say it was.
Thank you for this.
In the box that says 3 phase I'm guessing that is blank and in the single phase PH1 I'm putting 3.6kW and then 1 in the power factor box?
