A_L Posted January 14, 2021 Posted January 14, 2021 19 minutes ago, Jason L said: Hi. Can you explain what decrement delay is please? At the simplest it is the time taken for energy at the outside of a wall to transfer through to the inside. https://www.concretecentre.com/Publications-Software/Design-tools-and-software/Dynamic-Thermal-Properties-Calculator-(1).aspx from the middle of the link :- Quote This is a property of thermal mass which describes the way in which the density, heat capacity and thermal conductivity of a wall for example, can slow the passage of heat from one side to the other (decrement delay), and also attenuate gains as they pass through (decrement factor). Designing for a long decrement delay of around nine hours or more, and a low decrement factor can help reduce overheating problems in summer. 2
BartW Posted January 14, 2021 Author Posted January 14, 2021 1 hour ago, Buzz said: So £21m2 to get to .14 in pir , thanks i have somewhere to start ?, going to need somewhere close to 400m2 ?. Is that your roof size? Blimey, how big is going to be your house ??
Buzz Posted January 15, 2021 Posted January 15, 2021 Building a bungalow , about 260 foot print (at the moment ) got to have a high ridge to match the street view , so pricing for 400m2 and hoping for less , every little helps?
TonyT Posted January 15, 2021 Posted January 15, 2021 if you are going for PIR, you need to factor in expanding foam, foil tape etc too. I wish I had shares in foil tape and expanding foam before starting
Gone West Posted January 15, 2021 Posted January 15, 2021 11 hours ago, Jason L said: Hi. Can you explain what decrement delay is please? It's the rate at which heat is lost through a material. It's difficult to model accurately and there are endless constructions to reduce the effects. The effects are more pronounced where there can be a build up of heat on the outer surface such as on the walls of a well sheltered house. Where we are, near the coast in an open area, the effects are non existent because when the weather is hot there is always a sea breeze. https://www.greenspec.co.uk/building-design/decrement-delay/ 1
