I’ve got to get a new roof on a rental . I mean a complete removal. Then ...
Strip off old tiles and felt and batten, removing all rubbish as we go
Renew felt with new breathable roofshield felt and 25x50 treated batten
Remove all lead work and render to all parapet walls and coping stones
Renew all lead work to all walls and chimney stack and dormas to the back
Use new stainless steel belcast beeds
Use existing tiles and put back onto roof replacing with new as and when we need to
Re-render wall back in using 2 layers of sand and cement
Renew velux windows like for like (these may have to be plastered around the inside of windows if they do not come out correctly which we do not cover)
To finish we will rebed new coping stones back on with a DPC Barrier
We will then ridge off the roof using new breathable dry ridge kit
My quote includes the cost of scaffolding and all rubbish removal from site
Why replace the velux ? Or is it not advisable to make a new roof for existing velux ?
Also is it worth replacing all the tiles or just reuse the existing - cost extra is 700
thanks
If there are a fair few tiles that need replacing I would renew the lot as the new ones will not match and the old ones are probably past their useful life.  With Velux if they are OK and a current size you could leave.  If not, replace.
Easy for me to say as it is your money.
The velux will be fixed to the old battens so it's going to have to come out anyway. It's just up to you if you want to put in a new one. How old is it??
I would reuse the tiles if they are in good condition and put the £700 towards the new velux window.
Good point, weatherproofing collar and flashing kit will be hard to re-use with any confidence
I know tiles lose their glaze overtime . Roofs probably not been touched in 20 yrs since I’ve owned it . Roofer also offers a 10 yr warranty so tempted to replace the tiles also . Then everything is covered in the event of any further issues .
Edited by pocster
New velux is included in his quote anyway .
If the tiles are only 20 years old I would be inclined to re-use existing as should be good for another 30 years at least I would have thought unless they are damaged or in poor condition.
