shbrooks Posted December 29, 2020 Posted December 29, 2020 Hello all. I'd like to install a number of lights around the perimeter of my medium sized garden to uplight a few trees and shrubs - probably 4 to 5 lights in total. Having recently replaced all of our fences, I currently have a trench I can drop a duct into and install the lighting cables at a later date. I originally thought I could bury a duct and have duct 'T' points which allowed each light to be served by a separate cable. However, I couldn't find a suitable sized duct with 'T' points, the smallest being 110mm, which I found was too large. I'm now planning on running a single cable in a duct, which rises above the surface at each lighting point and into a junction box, which then has a tee-off into each light. The main cable/duct then dips back below the ground until it reaches the next lighting point. Presuming this is possible and a more suitable, what size cables and ducts would I need?
ProDave Posted December 29, 2020 Posted December 29, 2020 Steel wire armoured cable, buried direct if you like, at each light point bring it up to a waterproof junction box and loop on to the next one. you need a big enough junction box to get 3 waterproof glands into the bottom.
shbrooks Posted December 29, 2020 Author Posted December 29, 2020 1 hour ago, ProDave said: Steel wire armoured cable, buried direct if you like, at each light point bring it up to a waterproof junction box and loop on to the next one. you need a big enough junction box to get 3 waterproof glands into the bottom. Thank you ProDave. I'd rather use ducts I think, so I can get the duct in the ground and pull the cable through at a later, and also add/replace any cables if they become problematic in the future. Any ideas what size SWA cable I need?
ProDave Posted December 29, 2020 Posted December 29, 2020 It it is just for lighting, 1.5mm SWA is all you need.
Onoff Posted December 29, 2020 Posted December 29, 2020 If you can stretch to it then Pratley underground boxes are excellent.
Temp Posted December 29, 2020 Posted December 29, 2020 I would also go with SWA direct in the ground. You can leave a loop where you think you need a light. Then use either a potted junction in the ground or post mounted box. If you use duct I wouldn't use T joints. I'd just bring the ends of the duct up like this.. UUUU
ash_scotland88 Posted December 29, 2020 Posted December 29, 2020 2 hours ago, ProDave said: Steel wire armoured cable, buried direct if you like, at each light point bring it up to a waterproof junction box and loop on to the next one. you need a big enough junction box to get 3 waterproof glands into the bottom. Is this to "standard?" Planning on my own garden install and I thought power had to be burried to a depth, gravel, marked etc. Or is that only for running mains to out buildings?
Temp Posted December 29, 2020 Posted December 29, 2020 (edited) I think the recommended depth is 600mm with 450mm minimum. That's about how deep our swa cables are. Can be shallower if protected. Should be a marker tape above it but don't think ours has. No gravel either. Edited December 29, 2020 by Temp
