Do you??
We’re at first fix stage and a discussion has started about drinking water that’s been softened vs leaving kitchen taps on hard water.
Apparently it tastes yuk. Personally I think practically all tap water tastes yuk, but does it taste really rank?
If you have a water softener do you drink it and do you like it?
From our experience I wouldn’t say it tastes yuk,  but it’s definitely not as pleasant to drink as the water from the kitchen sink without the softener. I would leave the kitchen sink taps hard and will be doing so on our current build.
I guess it depends a lot on your local area though. North west Wiltshire here.
We have had water softeners for nearly thirty years and Wendy drinks tea and coffee made with softened water. I rarely drink hot drinks but drink cold water and use a water filter.
I drink naturally occurring softened water all the time, but always filter when I am at my Mother's as you can see the chalk in her water.
I prefer my water, even if it is the most expensive in the country.
Do you filter hard or soft water?
I filter hard water but don't remove the hardness, so only Chlorine, Nitrates etc are removed.
On 01/12/2020 at 00:02, Mandana said:
Do you??
Bit late to this, but I believe building regs requires you to have an unsoftened outlet (and maybe even requires that to be in the kitchen).
I drink softened water all the time (bathroom tap) and it tastes fine to me.
