Repairing a rotting fence post tips
AdamD
As per the title, help! Slightly rotting fence post which is quite loose, any tips on repairing rather than replacing (it is in a really awkward position to replace)? Pic attached.
Anyone used post buddy? https://postbuddysystem.co.uk
You can use a wooden "Godfather post" or a concrete "Fence Post Repair Spur" - 1.2m metre concrete post with boltholes ?.
If there is a hunk of concrete in the ground you get 400mm or so of fence post and use it as a spacer so the Repair Spur is say 100mm away and use long bolts through all 3 elements to miss the concrete in the ground with the repair spur.
Alternatively you can try and put the new one in the same hole like this:
Ferdinand
