Jeremy Posted November 14, 2020 Share Posted November 14, 2020 (edited) Just getting my head around wall construction and the balance of vapour, heat and draught resistance and how they work together. I'm planning to renovate my walls (internal, as neighbours in the terrace aren't necessarily enthusiastic) house-wide - the solid double-brick victorian design (basically just bricks with plaster on it) has some significant room for improvement. But there are a dizzying array of options and configurations for internal wall insulation and it seems like information "out there" hasn't quite kept up with our developing understanding of water vapour and airtightness. Here's my current understanding, am hoping folks can correct me where I'm wrong (from outside to inside): 1. The air outside: The weather here in the UK is rarely on average over 21C, so the inside of the house will almost always be warmer. So the design needs to address water vapour that is *leaving* the house, getting cold and turning to condensation at some stage during its exit from the inside rooms. Not much reason to worry about water vapour coming in from outside. 2. The outer structural layer, that is in my case a solid double brick layer has a Vapor Resistivity, N s/(kg m) of 45 - 70 (got that from here: from here: https://www.engineeringtoolbox.com/vapour-resistance-d_1807.html). This means that it is "semi-permeable" 2b. Leaving on plaster (or not): Most of my walls have plaster (in some cases lime plaster, but haven't done an exhaustive survey), which I gather is straight-up "permeable". I can't see a consensus as to whether it's better to remove or not remove plaster, but I gather it may be necessary to remove (a) so that one can assess damp problems in case they aren't fully permeating the plaster to the inside layer of the wall (to show on paint etc.) and (b) so as to install some sort of membrane, or (c) obviously to address where there has been damage, and it seems to make more sense to leave it off if it's already off. But it seems like some folks like to save time and energy by leaving it on if there aren't mitigating situations. I'm about 70/30 leaning towards removing paint and plaster to expose the brick and check things out properly. 3. Air gap (or not): I've noticed some disagreement as to whether an air gap is now necessary. I gather an air gap is needed so that air can circulate vapour so that it can evaporate or vent out through the brick wall rather than condensing as it might in a tighter space without air. For the air gap, I can do battens over walls - and it seems that wood and stainless steel are the likely options here, nailed or screwed. Steel is more expensive, but will avoid rotting better than wooden battens (though damp proofing should ensure this isn't happenning!). Seems like Damp Proof Membranes are also an alternative, but a bit of overkill for my purposes here as it's not a cellar and all walls are above ground. But then the 4. PIR boards. I'll get these with foil backing, as this has an astronomical Vapor Resistivity value (4000), putting it on the very high end of "vapor impermeable". But it seems that some folks prefer the more labour intensive but easier-on-battens-long-term "warm battens" approach, where a insulation is split into two layers (a) a membrane is put down with half or more in layer of foil-backed insulation and then (b) an inner layer of battens with more insulation boards inbetween. This keeps warmth around the battens and ensures that moisture will condense further out in the wall. This seems reasonable to me - and I don't mind the more challenging job if there's an efficiency to be gained. What I'm not sure about is whether to use a membrane or foil-backed insulation boards for the vapour membrane at this stage. And if I use a membrane can I skip the air gap? 5. Plasterboard. "semi-permeable" here, skim on some plaster and ready to go. With regards to thermal transfer and insulation performance, here's what I've got: 1. Air = cold 2. Brick wall has u-value of 2 W/m²K or so 3. Air gap will reduce this slightly 4. PIR boards have a very low U value, which is why they'd be preferrable in walls to various wolls, cellulose, or other good options. I'm aiming for 70mm PIR or more (if possible) to try and get as close to or lower than my target U-value of 0.30. 5. Plasterboard adds a bit here too, but not much. Compliments of diydoctor, here's a diagram of what I'm doing: Option 1 (keep plaster, cold battens): Option 2 (warm battens - ignore blocks in picture): Option 3 (with service void): So questions are: (1) Is there a way of adding internal wall insulation on a solid double brick wall using new "tech" which will enable me to skip the air gap? (2) Should I strip plaster off the wall? (3) What's the best material for battens? (4) Any tips on how/whether to do a service void? I'm going to wire the whole house with ethernet and rewire electrical, so this wouldn't be out of place. (5) I've noticed comments elsewhere by @Jeremy Harris regarding a need to do graded vapour permeability, starting with (as he suggests): "the least vapour permeable and the outermost layer is most vapour permeable". This approach seems to be pretty difficult with internal wall insulation. Or am I allowed to ignore the plasterboard for the purposes of this kind of calculation? Would love to be enlightened. Note: this was quite helpful: https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/658604/BEIS_-_SWI_Innovation_Final_Report_-_FINAL_Approved.pdf Edited November 14, 2020 by Jeremy Link to comment Share on other sites More sharing options...
nod Posted November 14, 2020 Share Posted November 14, 2020 One thing I did notice is your batons are out of date now A gypliner system will give you far better soundproofing and is much quicker to install Also you could leave the plaster in place if you didn’t fancy knocking it all off 1 Link to comment Share on other sites More sharing options...
tonyshouse Posted November 14, 2020 Share Posted November 14, 2020 What overall U value are you aiming at? Link to comment Share on other sites More sharing options...
Jeremy Posted November 15, 2020 Author Share Posted November 15, 2020 9 hours ago, nod said: One thing I did notice is your batons are out of date now A gypliner system will give you far better soundproofing and is much quicker to install Also you could leave the plaster in place if you didn’t fancy knocking it all off Nice! I'll check that out. Had a feeling I might have been missing some updated info based on my internet research. Link to comment Share on other sites More sharing options...
Jeremy Posted November 15, 2020 Author Share Posted November 15, 2020 8 hours ago, tonyshouse said: What overall U value are you aiming at? Probably 0.25 or so. Replacing windows with PVCe double paned, adding loft insulation, membrane and osb boarding to attic to get around 400mm and floors with 100mm PIR or thicker wool, but not quite sure what the final figure will be at. Link to comment Share on other sites More sharing options...
Jeremy Posted November 15, 2020 Author Share Posted November 15, 2020 3 hours ago, Jeremy said: Nice! I'll check that out. Had a feeling I might have been missing some updated info based on my internet research. So looks like, for about 75 linear metres of wall with 3m per floor, I'll need: - 25 Gypliner GL8 steel tracks (for floors) - 175 Gypframe GL1 Lining Channels (vertical) - 2x 100 packs (for 175) GL2 gypliner brackets - 6x 200 packs of gypframe GL11 GypLyner Anchors That's under £1k at https://mybuildersmerchant.com (£888 including VAT), which isn't too bad. And the system is designed so that I can install 20/25mm conduits in the gap for services, which is nice. Their integrated panels are, however, *very* expensive. Around £10-12k for Gyproc ThermaLine super / PIR for the 200m2 that I'll need. So, seems like sticking with generic foil-lined PIR boards and plasterboard, which is around £2.5k is a preferrable option, unless anyone thinks the £7-8k difference is somehow worthwhile. Thanks for the tip! Link to comment Share on other sites More sharing options...
Jeremy Posted November 15, 2020 Author Share Posted November 15, 2020 2 minutes ago, Jeremy said: So looks like, for about 75 linear metres of wall with 3m per floor, I'll need: - 25 Gypliner GL8 steel tracks (for floors) - 175 Gypframe GL1 Lining Channels (vertical) - 2x 100 packs (for 175) GL2 gypliner brackets - 6x 200 packs of gypframe GL11 GypLyner Anchors That's under £1k at https://mybuildersmerchant.com (£888 including VAT), which isn't too bad. And the system is designed so that I can install 20/25mm conduits in the gap for services, which is nice. Their integrated panels are, however, *very* expensive. Around £10-12k for Gyproc ThermaLine super / PIR for the 200m2 that I'll need. So, seems like sticking with generic foil-lined PIR boards and plasterboard, which is around £2.5k is a preferrable option, unless anyone thinks the £7-8k difference is somehow worthwhile. Thanks for the tip! Should I use 12.5mm plasterboard for this? Or is something thinner ok? And how much plaster is usually added on this? I'm assuming 10mm base + 5mm skim might be excessive... Link to comment Share on other sites More sharing options...
PeterW Posted November 15, 2020 Share Posted November 15, 2020 5 minutes ago, Jeremy said: Should I use 12.5mm plasterboard for this? Or is something thinner ok? And how much plaster is usually added on this? I'm assuming 10mm base + 5mm skim might be excessive... Use standard board everywhere unless it’s in a wet/damp room and then use Moisture Resistant board (usually green). Your top skim for boards is 3mm of either board finish or multi finish plaster. 1 Link to comment Share on other sites More sharing options...
