Hi — I'm trying to arrive at some rudimentary budgeting figures for a potential self-build project my OH and I are hoping to embark on so we can see what's possible in terms of size and spec. I've followed a few basic financing and budgeting formulas that have been suggested to me but i'm not sure whether my calculations are correct and whether i'm accounting for everything that needs to be considered. What i'd like to arrive at is...
1. A rough idea of our potential construction budget
2. An approximate house size in sqm based on this budget
Below are the figures i'm currently arriving at. Any advice on whether i'm doing this correctly or what the correct figures should be would be fantastic.
Joint household income: £295k
Multiplied by 3 to arrive at a potential maximum mortgage: £885k
Plus current savings: £50k
Plus equity in current house: £300k
Equals a total budget of: £1.235m
Based on land being 1/3rd of this figure and the build being 2/3rds:
Land budget: £411k
Self-build budget: £822k
From the self-build budget i've deducted 20% / £164k for all the fees (architect, structural engineer, M&E, QS, building control, planning fee, party wall fee)
I've then deducted 20% / £164k for contingency
This leaves a final construction budget of: £644k
And a potential house size of:
Low spec (£2000 per sqm) = 322 sqm
Mid spec (£2500 per sqm) = 257 sqm
High spec (£3000 per sqm) = 214 sqm
We can borrow £600k with ecology.
paying £350k for the plot.
building 225sqm for £300k (might have to stretch to £350k) [£1300-1600/sqm] at a good spec but doing as much work ourselves as possible.
think your £/sqm are high depending on your build route. Are you planning on using a turnkey style build, main contractor or subies etc? These have a huge impact on cost independently from spec.
You can probably achieve anything you want with that budget depending on what you can do yourself. even just doing admin for the builder or shopping around for materials has already allowed us to spend saved money on nice things like ASHP and my wife’s ‘required’ aga!
Had one as a kid. Loved cooking on it and coming in from the rain and basically hugging it to keep warm.
I’m expensive to run too, and we’re getting one with a handy new invention called an off switch. Specifically designed for the 3 weeks a year the uk has a heatwave!
  On 28/09/2020 at 21:27, Mr Punter said:
I have had one of these and I would advise DON'T!
Sweltering in the summer, crap to cook on, expensive to run.
Expand
Expand
I now live in a new house and it would easily overheat with an Aga.  No heatwave required.  So will yours if it is built properly.
My Aga was in a cold Victorian detached with solid walls, so it was nice to come home to.
Being slightly contrarian, can I recommend that as a foil you also do a "needs" analysis from the other end - a list of spaces and facilities that you need. Particularly in the London, house values are currently questionable having gone down for each of the last 3 years.
Suspect that you may  do this anyway, given your approach on the forum.
It's good to know what you can afford, but there is no reason why you need to spend to the max. Having some headroom is a good thing to do.
Whenever I go to Town I love window shopping all the expensive boutiques for the things I don't need to buy any more than I need to buy a polka dot hippopotamus.
Edited by Ferdinand
Expand
Yes we're slowing putting this together.
Expand
Is this in reference to the house we currently own (and have equity in) being in London? We won't be selling for 3-4 years yet so can't really foresee what the market will be like then.
If you're suggesting the self-build will be in London, it won't. We're looking to build outside of London but ideally somewhere in the South East (land budget allowing).
  On 28/09/2020 at 21:16, ZacP said:
Think your £/sqm are high depending on your build route.
Expand
As this is our once in a lifetime 'forever home' (at least that's the plan) we do want to create something of a relatively high standard. I'm a designer by trade (sadly not in a field related to architecture or construction), and the aesthetic of the house is extremely important to us. We'd like to work with a very good architect who can deliver in the style we want and that could impact on our cost. Not that i'm considering using this company but i love their work but they clearly state on their website that projects they take on typically have a cost per sqm starting at £3500(!)
https://www.stromarchitects.com/architecture-one-off-contemporary-houses/
Expand
At the moment i think main contractor is the route for us with the architect doing a series of site visits to ensure the plans are being followed correctly, then i'll be overseeing the project management side of things (timings, researching and purchasing of not construction fixtures and fittings etc).
Is this a cost effective route?
Land budget: £411k
Expand
Do these figures seem right and have i done the self-build estimate correctly?
Is 20% the right amount to factor in for all fees?
Is deducting 20% at the outset the right way to account for contingency and is it enough?
Expand
It is just a note that the London market is going to be very difficult to predict.
There was a piece in the FT this week claiming that it was booming, which I think very irresponsible.
F
If its your forever home then I would consider that you may be wanting to make changes over time (e.g. making sure there is an area for a lift) so if it were me I'd spend a bit more on the structure, insulation, footprint, design, etc etc - things you can't easily change in the future. Then if the budget comes in tight to the end and you run out of contingency you can always fit a less expensive kitchen or bathrooms to save a number of 10s of thousands of pounds. Then revisit in 5-10 years and put in something all singing all dancing that you wanted in the first place. It's relatively easy to upgrade these things, but much harder to fit underfloor heating or more insulation or similar to some designs at a later date.
Hope that makes sense.
p.s. if they say their project start at £3500 then they're likely to be much much more then this! Any decent architect should be able to design something along the lines of what you're looking for. Create a Pinterest board and send that to a few to see how excited they get!
p.p.s. yes, main contractor is usually the more expensive route, investigate things like fixed price contracts to mitigate your budget risk further. More expensive, but likely to take the stress out of the build a bit for you.
p.p.p.s. sounds like an exciting project - good luck!
Edited by ZacP
Expand
Yes completely agree, we're more than happy to think economically with regards to fixtures and fittings. We don't necessarily desire a bank busting Gaggenau kitchen for example, we achieved a really high finish in our current home on a budget by spending time to research some choice products. For example our current kitchen is Ikea carcasses but doors and work surfaces made by a danish company called ReformCPH who specialise in fronts designed by architects and built for Ikea cabinets, 3 years later and it still looks and works great! We'd be happy to do this again and if we do win the lottery 10 years down the line, well! :)
Expand
Thanks! Definitely exciting, if not slightly nerve-wrecking ?
Expand
I wonder whether architects here would care to comment. What strikes me about these homes is that they are very similar and in many cases seem to choose form over the convenience: I seem to remember cantilevered parts present a significant cold bridging problem. But again, that's for a professional to confirm.
Expand
I think any architect tends to have a house style, which is why it is so important to look at previous work.
Expand
We don't have a house style - we are more driven by what style the client wants (but my previous office did have a style which was kept to)
Strom are very particular, they state a minimum m2 price to deliberately cut people out of wanting to work with them, they'll only do the projects where the client wants to achieve that style/look and have enough money to deliver it. You wouldn't just phone them up and get them out for a chat... They are internationally renowned for their style and their focus is solely on their ideal clients.
Expand
What can I say... Great to be able to work like this (not a hint of sarcasm here).
Expand
To be fair to him, it's the absolute perfect setup, only do projects you want to do with clients who really want you to do them.
We all use some subtle types of qualifying in our websites/social media...
  On 30/09/2020 at 17:24, oldkettle said:
3.5K+/m2 you call subtle? ?
Expand
For that type of project it's light if anything, for high end clients they don't care about the costs, they care about the quality of the end result.
If you're cost driven then you're not the right client for that practice. The only reason anyone ever puts minimum build costs on their site is to discourage enquiries from dreamers who think they can achieve that quality for buttons.
He isn't targeting self builders looking to make savings on build methods/finishes/consultancy ...
Some are more subtle than others
Edited by the_r_sole
