epsilonGreedy Posted September 22, 2020 Posted September 22, 2020 Treated/Untreated C16 or C24 Rough sawn so it grips the mortar bedding or just normal smooth wood I am also getting mixed messages on the thickness. Local trades assume 50mm is fine whereas technical resources indicate it should be 75mm thick. My wall plate is supporting trusses as 600mm centers, the inner wall blocks are fibolites (heavy end of light) and the roof cover is natural slate.
Russell griffiths Posted September 22, 2020 Posted September 22, 2020 No need for treated your trusses won’t be.
Mr Punter Posted September 22, 2020 Posted September 22, 2020 31 minutes ago, Russell griffiths said: No need for treated your trusses won’t be. But the wall plate sits on the masonry. I would def make sure it is treated.
Russell griffiths Posted September 22, 2020 Posted September 22, 2020 39 minutes ago, Mr Punter said: But the wall plate sits on the masonry. I would def make sure it is treated. How is it getting wet ??
epsilonGreedy Posted September 22, 2020 Author Posted September 22, 2020 1 hour ago, Russell griffiths said: How is it getting wet ?? My trusses sit on the inner block wall so in theory the wall plate seat should be dry. Boxed eaves should help as well.
