Hi all
I am restoring an old lime and stone church. I'm looking at Hanson Hydrated Lime which they say won't stick without concrete. I assume I can't add concrete to my lime mix? I have seen that rough sand may provide just as good a stick? Any help would be very much appricated.
Thanks
Justin
I shal be randering and plastering, but plastering will be first. Basically the whole building needs a bit of a lime going over.
10 minutes ago, Justin Tuijl said:
Can the Hanson Hydrated Lime  be used to make putty lime?
I think it can if you add water and leave it for a while (weeks / months) but I think the lime putty is supposed to be better.  Never used it myself and it is quite a specialist area.  If it is conservation type work do not use any cement at all.
If you need a bit of practical advice
Any of the colleges with a plastering course still use both line sand and putty lime
As it can be easily chipped off Then ground up and continually reused
If you need advice and a lot of lime then get in touch with Mike Wye - probably one of the best and most knowledgeable suppliers of lime products.
Hydraulic lime is what you want not hydrated. Hydrated is used more like a plasticiser.
You can do all rendering/plastering with hydraulic lime and sand, no putty needed - a lot cheaper I would think.
I would use sharper sand for scratch coats and a finer plastering sand for finish.
Is this external as weather protection and internal?
Is it a conversion or just staying as a church? If a conversion how are you insulating?
