I would be using a cheap TMV to blend the water down inside to 30-32c and then have a pair of isolators / taps so you can isolate in cold weather inside to protect from frost but use it externally with a single tap.
ha, great minds think alike , I was just about to say exactly the same but make sure pipework goes straight outside or go downwards so no water is held in the outside tap to freeze.
  • 2 months later...
After a great deal of procrastination I was about to get stuck into doing the outdoor shower... then I  thought up an excuse to delay it a bit longer... The previous location I was thinking of would have been good for getting hot water, but not the best position for a shower area.
I have water (cold only) and power further out in the garden.... So I was thinking, could I have an electric shower outdoors? Wouldn’t need to be a big kw one as it will just be for the dog wash, and occasional use in the summer.
Any comments?
Edited by Gav_P
If you've local hot and cold water why not just have a tmv inside and a standard, garden bib tap on the outside?
Because I am thinking about putting it in a different (better) location which isn’t anywhere near the house (hot water).
53 minutes ago, Ferdinand said:
If you are procrastinating then it is likely there is not much difference.
So toss a coin.
Shakespeare, Julius Caesar: "The problem is in ourselves."
Does Julius have any advice as to whether one could use an electric shower outdoors?
Maybe my previous explanation wasn’t very clear.
I am planning on installing an outdoor shower, primarily as a dog wash, but could also be used in the warmer summer months (like after swimming in pond/pool).
I had originally planned on a location to place it based on hot and cold water nearby (next to the house). However the location isn’t ideal, so probably the reason I hadn’t cracked on and done the job.
I then thought that if I could have an alternative means to heating the water then I could locate it where I have other cold water feeds (near the bottom of the garden). Hence wondering if it’s possible to use an electric shower outdoors.
Apparently he had a pond, a hypocaust, and a garden divided into three parts. So no electric required at all.
His dog was called Dai and when he had thrown it into the pond for a good scrub he used to declaim “Alea iacta est.”
Best I can do after dinner and beer .. sorry. Unless you want a thirty minute Pink Panther cartoon about arguments over a shower.
(What was this thread about? I am sure it was probably something else.)
  • Haha 2
Bloke had some gaul.
  • Haha 2
There are certainly outdoor showers available .. perhaps try looking at swimming pool kit suppliers and outlets?
