AlanUK Posted August 25, 2020 Posted August 25, 2020 My new garage is built from brick and block, and I want to paint the inside blocks. Which paint should I use? And is an undercoat needed?
Mr Punter Posted August 25, 2020 Posted August 25, 2020 I have used masonry paint. No undercoat but watered down first coat. You could just use emulsion if you want. 1
Ferdinand Posted August 25, 2020 Posted August 25, 2020 Suggest a long pile roller, or perhaps spray if you can. 1 1
PeterW Posted August 25, 2020 Posted August 25, 2020 Wilko Silk emulsion paint, long pile roller and he first coat at 20% added water. Will need 3 coats but will be fine for years ..!
scottishjohn Posted August 25, 2020 Posted August 25, 2020 (edited) success with emulsion will depend how rough and porous the blocks are- and how good a finish you want its not the right thing --but may work if blocks are very smooth -masonry paint is the right stuff I would certainly leave it a week after first coat before applying next one Edited August 25, 2020 by scottishjohn
AlanUK Posted August 25, 2020 Author Posted August 25, 2020 Thanks John. Would you concur with Mr Punter above about watering down the first coat too? 2 hours ago, scottishjohn said: success with emulsion will depend how rough and porous the blocks are- and how good a finish you want its not the right thing --but may work if blocks are very smooth -masonry paint is the right stuff I would certainly leave it a week after first coat before applying next one
scottishjohn Posted August 26, 2020 Posted August 26, 2020 8 hours ago, AlanUK said: Thanks John. Would you concur with Mr Punter above about watering down the first coat too? y es. my garage was steel frame and blocks --very rough finish ,so were suggested and used a special 2 part under coat which sealed it all and filled in surface holes --then one coat of gloss paint --still shines now 30+ years later . years later I split in to 3 units and just used silk emulsion I was suprised again how it just sucked it up - but seems to be as good a finished job --just not as cleanable like true gloss paint ,but would be fine probably for a domestic garage. a modern masonry paint will be better to clean, I think but will cost more used an airless industrial sprayer -used much more than I calculated due to blocks sucking it up ..540sqm !!
