Rendering foundation blockwork below SIPS sole plate
Longjock
Hi guys,
I've got to crack on with making the decision on what to use for the area of blockwork below the sole plate. The drawings show to use EPS and Stolit K up to the dpc level but after speaking further to the architect, he has suggested in carrying the eps up over the sole plate to aid with the thermal bridging in that area.
The external walls will be vertical timber clad down to this level so the top surface will be hidden and the lower edge of the rendered area will have shingle up to it in the 'drip area'.
My dilemma is that everything I look at online about rendering on EPS is based on full walls, rather than this area. Do I have to follow this process (starter beads/adhesive AND mechanical fixing etc.) or is there a more cost effective/simpler way of getting the job done.
All the local 'trades' round here, only ever talk about sand and cement but I know this won't work with EPS.
Any help given will be appreciated.
Edited by Longjock
If your asking can you render under the dpc onto the eps
The answer is yes I am often asked to do this I normally say put stones or shingle against the render Or if you decide to flag
run dpc against the render to flag to leaving about 10 mil sticking up
Cheers @nod , the shingle up to the render is the plan.
I’ve just looked at the HP12 and it says it’s good for fixing the eps to the substrate, but are you saying to then use this as the following basecoats (with mesh)? Do you then put a top coat on or just paint?
I’ve never had to look at any rendering before, hence the understanding of this process.
Edited by Longjock
Yes no problem
Yes you would apply the HP12  directly to the EPS About 3 mil thick Then press the fibre mesh on to the base coat Run a trowel I’ve it  then give it a light skim coat of HP12  ( Backing coat)
Then after about an hour give it a ver light scratch
You can apply a 10-15 top coat  any time after 24 hours
  Hope this helps
  • 4 weeks later...
Hi guys, finally getting round to starting on this. I’ve primed the blockwork ready to stick the eps on to, but I’m not sure about the dpc sticking out from under my sole plate. Do I tuck this down behind the eps board or do I trim it off or what?
  • 3 years later...
