hi just had a kit house completed.
Doing all the door linings and hanging doors myself.
It's quite modern finish and love the 'achitrave-less' look
I was speaking to a joiner who said that i'll always get cracking where I fill and paint at the junction between my door lining and wall.
But there must be a filler mix or other trick that can withstand the vibrations of door latch vibrating lining?
any ideas
thanks in advance
Oliver
There’s a bit more to it than just leaving the architrave off, as that will crack over and over again, it’s something that needs looking into before you board the walls, or at least before you skim depending on the trim you use.
Its certainly a more expensive job than having architrave.
any ideas
thanks in advance
Oliver
You would need a bead taped onto the edge of the board before it’s fixed It’s normal to allow a three mill gap between the bead and casing
42 minutes ago, jfb said:
Do you mean something like this?
https://www.buildingmaterials.co.uk/plasterboard-edge-beads
What happens to any packers used to set the door linings - won't they be visible?
Yes exactly like that
We mainly use them for shadow gaps
and where a board butts up agains an ally frame
Tap onto the cut edge of the board and staple the webbing every 200
