Hi
My outside wall are going to be 100 mm block then 100 mm stonework tied into the block approximately half way up the building then it will change to white render.  Is there any way to stop a lip where the block meets the render as the render will be thinner than the stone
thanks
Normally when they are half and half The block work is set in 25 mil
Otherwise you would be looking up at the underside of a stop or bellcast bead
Not sure I understand as if I set the block in 25mm it would be in half of the cavety
if you've got 100mm stone, with 100mm block on top, the render finish will be outside the line of the stone (it won't be thinner like you suggest)
So you'll need a bellcast detail at the bottom of the render
Sorry, misread the op!! ignore me! what's above the stone to carry the render?
Edited by the_r_sole
Then set the stone out
You need a definite line for the render or the bead to sit on
Most of the ones I render finish with a rectangular block of stone running under the BW
the render needs to go on something! Are you planning on using a carrier board?
Tbh, I would put a stone cill to finish off the top of the stone and keep the lip - then it will look like you've got a thick stone wall!
Cheers for that.  that is a thought
