Hi Guys,
I'm about to plasterboard my utility room, and need some help choosing the correct plasterboard type. The drawing call for fireline plasterboard throughout, but do you think moisture resistant plasterboard would be better for a utility room?
Thanks!
I would be questioning why the drawing calls for fireline throughout. That is not normal. But I would want to be sure before I ignored that.
Where is fireline usually required then?
Just now, PeterW said:
Timber frame and gas boiler in there ..??
Timber frame and oil boiler.
There is a gas hob in the kitchen though fed from an external gas tank.
The only place my drawings specified fireline was in the attached garage, as two layers with staggered joints.
9 minutes ago, Ben100 said:
Yes, and an unvented cylinder.
Going for 60 min then in there - I would for the additional cost and also it’s good for noise.
60.. millimeters?
46 minutes ago, Ben100 said:
Hi Guys,
Thanks!  Fire board on a utility ceiling won’t be of any benefit Unless you are creating a fire compartment within the room
Fire door and frame also
If there is an integral garage we often carry the utility ceiling through if it backs onto the garage But would always be two layers of 15 mil
Or if over three floors to protect a steel
It will cost about a fiver a board to use FL So if it’s only a couple of boards it’s not worth the phone call
