Shouldn’t be any hardcore nowadays.
Type 1 compacted
sand blinding
dpm.
Concrete
insulation
screed.
Or alternatively.
Type1
thin insulation
dpm
more insulation
concrete.
Theres many ways to do it but hardcore and concrete should be left for a shed base, there is no way to compact it sufficiently to avoid voids in it.
3 hours ago, MAXWELL said:
What is the minimum thickness / amount of hardcore you should have as sub base for a concrete floor
Domestic floor?
My spec was 150mm compacted sub base with a 100mm concrete floor covering. Insulation and screed on top of that.
We've just done 200mm compacted type 3 under the main slab and 100mm under the load bearing walls (to bear 200mm and 300mm of concrete slab). There will be a blinging layer of sand to protect the tanking membrane.
Building control guy was surprised we had stone down and was wondering why were weren't going directly on to the clay!
