Hi Everyone,
I am looking to have a oft conversion and would need to relocate the tank from our system boiler to the loft, as it is currently in a cupboard above the stairs where the new staircase will go.
The tank will be moving straight up above where it currently is in a cupboard by the side of the new stair entrance in the loft.  Roughly how much do you think this would cost to complete?
Access shouldn't be an issue as the new stair shaft will be cut in the ceiling directly above it.
Many Thanks :)
If it’s been surveyed first, a good plumber should do that in a day. So £160 plus materials I suppose should be ample.
Will the tank have to have a timber plinth constructed to sit on at its new location? If so, factor in costs for that too.
First off is a vented or un vented tank, you may struggle for height for feeder tank if vented. If changing style of tanks the job may take longer than a day. Very hard to give you a rough price even on a simple job without seeing the job.
