Euan G Posted June 23, 2020 Posted June 23, 2020 Hi Does anyone have any experience/recommendations for stone cladding panels such as z clad, z stone, tier etc. Looking to use on bottom edge below render and on front aspect of living room. TIA
Declan52 Posted June 23, 2020 Posted June 23, 2020 You can get either real stone that has been cut down to 30/40mm slips or more regular shaped versions like z stone where stone is glued together to form the z shape. There are also concrete options where coloured concrete is poured into moulds but those won't stand the test of time. So first thing to choose is do you want it random pattern so it looks like real stone work or more straight lines, z stone or similar. Then it's pick a colour you like. You just use a good quality tile adhesive, swimming pool standard, to fix them to the wall.
Pete Posted June 23, 2020 Posted June 23, 2020 On 23/06/2020 at 11:51, Euan G said: Hi Does anyone have any experience/recommendations for stone cladding panels such as z clad, z stone, tier etc. Looking to use on bottom edge below render and on front aspect of living room. TIA Expand I am putting some Norstone on at the moment, will put some pictures on tomorrow
Euan G Posted June 24, 2020 Author Posted June 24, 2020 On 23/06/2020 at 21:23, Pete said: I am putting some Norstone on at the moment, will put some pictures on tomorrow Expand Thanks, how does Norstone compare on price and quality to other manufacturers?
Pete Posted June 24, 2020 Posted June 24, 2020 On 24/06/2020 at 06:40, Euan G said: Thanks, how does Norstone compare on price and quality to other manufacturers? Expand Not sure really as Norstone only did the stone that we needed
Pete Posted June 24, 2020 Posted June 24, 2020 On 23/06/2020 at 11:51, Euan G said: Hi Does anyone have any experience/recommendations for stone cladding panels such as z clad, z stone, tier etc. Looking to use on bottom edge below render and on front aspect of living room. TIA Expand Pictures of my Norstone cladding 1
Dan F Posted June 24, 2020 Posted June 24, 2020 On 24/06/2020 at 09:55, Pete said: Pictures of my Norstone cladding Expand Looks great. Is this Aksent Grey Basalt? We have the standard rock panels specified, but these looks good.. Did you order direct, or via a supplier?
Pete Posted June 24, 2020 Posted June 24, 2020 On 24/06/2020 at 10:07, Dan F said: Looks great. Is this Aksent Grey Basalt? We have the standard rock panels specified, but these looks good.. Did you order direct, or via a supplier? Expand Graphite Lava Stone, went direct to Norstone, guy called Jack Jago
Euan G Posted June 24, 2020 Author Posted June 24, 2020 On 24/06/2020 at 09:55, Pete said: Pictures of my Norstone cladding Expand That looks well!
SuperJohnG Posted July 1, 2020 Posted July 1, 2020 @Pete that looks great.....I'm away to find out where I can put some of this!
