SteamyTea Posted August 13, 2025 Posted August 13, 2025 16 hours ago, marshian said: Put it in the ground and put the root ball in a stainless steel washing machine drum If you plant two like that, you can hang a washing line between them.
saveasteading Posted August 13, 2025 Posted August 13, 2025 6 hours ago, SteamyTea said: plant two like that, The easiest tree to grow from a branch or root cutting.
marshian Posted August 14, 2025 Posted August 14, 2025 1 hour ago, saveasteading said: The easiest tree to grow from a branch or root cutting. Don't even bother to try Stick a low branch end into a pot - it will root itself - once rooted cut the umbilical cord so to speak and you have a new fig tree to pass on to someone else - done about 10 so far!!!
SteamyTea Posted August 14, 2025 Posted August 14, 2025 5 hours ago, saveasteading said: The easiest tree to grow from a branch or root cutting. 4 hours ago, marshian said: Stick a low branch end into a pot - it will root itself There is a fig tree in Moron Gardens that I always admire, thought about pinching a fruit and seeing if it grows in a pot. How long a cutting would I need to take to get a successful cutting?
saveasteading Posted August 14, 2025 Posted August 14, 2025 9 hours ago, SteamyTea said: How long a cutting would I need to take to get a successful cutting? i used about 300mm., mostly in the ground. i know that @marshian's will work too because I have great success with brambles spreading thus. Good idea actually and i do it with rosemary: just lay a branch on the ground with a brick on it. slightly snapping the branch seems to help too. not so convenient if pinching a bit from elsewhere.
