Concrete slab poored for garden room office
Ttw
I've had a concrete slab poored today and just found out from the contractor that he did the following.
100mm 40mm to dust compacted with a a dpm (visqueen thick guage) layed straight on top lapping up onto the inner skin of blockwork.
HE DID NOT USE A BLINDING OF SAND
instead he layed another layer of dmp on top of the insulation but not lapping the wall.
Then he poored the 100mm concrete slab.
In short
Crusher run compacted
Dpm lapping inner skin
Insulation
Dpm
Concrete
Am i likely to suffer damp issues? Fortunately its quite dry round with sandy conditions and great drainage.
Sorry to be long winded in my description.
Edited by Ttw
More information
On 09/06/2020 at 21:27, Russell griffiths said:
NO.
Thanks Russell, I thought not but pretty sure the visqueen dpm would be pierced by the 40mm crushed stone. The second dpm doesn't run up the 25mm insulation upstand but hopefully it will keep any damp at bay.
You also have an insulation layer that is pretty impervious to damp. Unless you have a very high water table, then you will not have a problem
Much appreciate your comment and yes it totally makes sense that damp won't be an issue. The next issue is finishing the build and keeping the overall height under 2500mm... I guess that's another topic
