Just connecting  hep2o fitting and just wondering if it needs a washer in the bottom? It does not come with a washer and the bottom seems tapered so I guess not but just thought i would ask anyway. TIA
Reading between the lines you tried connecting it just with ptfe tape and it leaked?
As above what is it connecting to?  if it's a tap, it's probably the wrong fitting for instance.
14 minutes ago, dpmiller said:
what's screwing into it? Flat faced or taper?
No, I put a washer and some thread sealant. It attaches to the back of a geberit toilet isolation valve and it is flat.
Wrong fitting ;)  You need a tap connector not a female 1/2” BSP as shown. The tap connector will have the seal inside it already ( assuming Hepworth ) so nowhere to go wrong.
