Boris Posted May 26, 2020 Posted May 26, 2020 Hi. We have a timber frame house, so external walls are very thick. Here is the door seen utility side, it goes into the internal garage. The door had to be hinged on the right side. From the utility it looks tacky. Door stop a nasty afterthought. We have thought about replacing the door stop with a wider piece of architrave. What do you good and wise people think ? Also any pics of your similar doors would be gratefully studied. TIA.
Redoctober Posted May 26, 2020 Posted May 26, 2020 Hi @Boris we too have a similar set up leading from our kitchen area into the utility room. See photos below as to how we overcame it. Doesn't look out of place and if anything, i feel it adds a bit of character. Two shots from the kitchen side showing the deep recess and then one from the other side, in the utility room showing it to be flush so to speak. I hope this helps. 1
ProDave Posted May 26, 2020 Posted May 26, 2020 My door to the garage is as above. I have several internal doors on wide load bearing structural walls and I had to make my own door liners, doubly difficult because they are Oak. 2
Boris Posted May 27, 2020 Author Posted May 27, 2020 Thanks Redoctober and ProDave, they look great. Our style of door is more like ProDave's. ProDave could you post a pic with a door open ? TIA
Mike Posted May 28, 2020 Posted May 28, 2020 On 26/05/2020 at 15:35, Boris said: Door stop a nasty afterthought. Expand That was probably a cheap way of meeting fire door requirements - a door to an integral garage must be a fire door. If you have a fire door with intumescent strips and smoke seals I would expect that you could use thinner door stops, and could probably replace them with an alternative timber, but to be covered legally you would need to ask the door manufacturer for advice (the Fire Door Alliance advise that the door and lining is certified as a set).
Boris Posted May 30, 2020 Author Posted May 30, 2020 Hi Mike it is a fire door, very heavy, with fire door hinges and strips. It is the look of it I object too
