14 hours ago, bassanclan said:
I imagine your bricks will use a brick as the cavity spacer when setting out, so will naturally go up to 103-105mm.
Rather than dritherm etc have a look at pumping in EPS beads. It works out around the same price and offers a better u value and full fill.
Interesting thought. I just took a look here and the lambda value looks the same as the more performant mineral wools like Dritherm Ultimate at 0.032. I guess it could be an option if supply is a major issue as can be put in after wall construction.
A nice thing about these Knauf insulations is that it uses ECOSE which doesn't use a Formaldehyde binder agent in manufacture.
22 hours ago, epsilonGreedy said:
Not necessarily, my brickie team overlooked this at their first two corners as they were so heads down. I
@epsilonGreedy I think Russell was saying that this is what should happen,regardless of the thickness of the wall.
2 hours ago, Oz07 said:
What is the big concern with formaldehyde products
I've never really took notice
nasty stuff, tissue fixative/ embalming fluid/ carcinogen.
