AndyW9999 Posted April 14, 2020 Share Posted April 14, 2020 I have 20mm polystyrene sheet to insulate the interior of the roof (the polystyrene is appropriate to this use, relevant BS EN standards - the 'outbuilding' is my new posh shed not a dwelling of any kind ? The roof (sloping not flat) is constructed of 20mm OSB on wood joists (photo) and covered with heavy duty bituminous felt externally. I'm thinking of applying the polystyrene direct to the underside of the OSB using a spray adhesive. Is it ok to do this?...Im wondering if there could be any issues with the OSB being 'sealed' both sides? Thanks Andy https://photos.app.goo.gl/hR3GJWvXyNuwqsVJ6 Link to comment Share on other sites More sharing options...
Cpd Posted April 15, 2020 Share Posted April 15, 2020 Have you more information on the insulation, sounds very thin..... what are you trying to achieve? How are you going to deal with cold bridges ? What will be your vcl ? Will the shed be heated ? More information required about the project will help people give you good advice. Link to comment Share on other sites More sharing options...
Temp Posted April 15, 2020 Share Posted April 15, 2020 I think spray on contact adhesive may dissolve polystyrene? https://taylortheatrics.com/2018/08/01/foam-adhesives-that-wont-dissolve-your-foam/ Link to comment Share on other sites More sharing options...
