jfb Posted April 14, 2020 Posted April 14, 2020 1 - is it ok to have a Consumer Unit located directly above a shower ceiling? 2 - is it ok to have ring mains cables/ 24 volt transformers in ceiling void above shower? 3 - cant seem to upload a picture so i will try and explain this one - ring main has sockets on two side walls and the cable runs at socket level along the middle wall: is it ok for there to be no socket on the middle wall and for the cable run to considered a safe zone?
ProDave Posted April 14, 2020 Posted April 14, 2020 Safe zones only apply to walls so anything is allowed above the ceiling. I don't understand your "consumer unit above a ceiling" question. There are rules about accessability and "above a ceiling" does not sound the right place. To create a safe zone you need an accessory in that wall. So if you plan to run cables round a room at socket height, you need at least one socket on every wall.
jfb Posted April 14, 2020 Author Posted April 14, 2020 I see Dave, thanks. The CU placement ideally goes in the space above the shower - its a vaulted barn roof with access from a mezzanine/bed level so will have room to get cables in.
ProDave Posted April 14, 2020 Posted April 14, 2020 1 hour ago, jfb said: I see Dave, thanks. The CU placement ideally goes in the space above the shower - its a vaulted barn roof with access from a mezzanine/bed level so will have room to get cables in. It's a separate room on a separate floor so the presence of the shower below in irellevant. It should still meet accessible heights etc.
Jenni Posted April 14, 2020 Posted April 14, 2020 Thanks for this thread jfb, I was going to ask similar questions this week, specifically about safe zones in ceilings, that ProDave has kindly already covered. Also safe zone related - are there any rules about how close cables can run adjacent to and over top of a door or window?
