Will be installing this soon .
As some of my floor is screed and some marine ply do I just apply the mat across both ? . As you can see there are a few gaps and the marine ply is a few mm lower than the screed .
What should I fill the gaps with ?
Should I ignore the slight height differences across the different floor materials and just lay the de coupling mat straight across ?
thanks in advance!
2 minutes ago, SteamyTea said:
This stopped me coupling.
Did you get your misses to pose for that photo ? . You’ve given me some dangerous ideas !!
thanks in advance!
You can use tile adhesive
But let it set before you put your 5 mil adhesive down for your Ditra
Ardex for the ply
Ardex for the ply
So ‘skim’ tile adhesive over gaps and marine ply to make a nice level surface ?
Yes
When using matting always do the levelling before the matting goes down
41 minutes ago, nod said:
Yes
Ahhh ! . Ok . Tile adhesive to ‘level’ it will only be a few mm thick . Not going to crack or anything is it ?
Guess I should pva the marine ply before applying the adhesive?
No it will be fine
don’t use PVA with tiles
SBR is more reliable
15 minutes ago, SteamyTea said:
No, effing CT 1, have you learnt nothing.
Of course ! . You are right ! . Why do I buy any other materials other than ct1 I don’t know !!
On 10/04/2020 at 18:02, Oz07 said:
I thought he said ardex to self level then stick matt down with tile adhesive
Yes @nod please confirm .
So SBR ply
Then Ardex to level ply with screed : which Ardex product ?
Then when all dry de coupling mat on top.
So SBR ply
Ardex adhesive to stick the matting to the ply
Sure .
But what do I use to build the ply level up ? So it’s level with the screed .
  • 1 month later...
Self level . To get level .  If you can change the ply for Hardie backer board.  It doesn't expand and contract like ply. Plus ply nowadays is poor quality.
1 hour ago, dave2878 said:
If there is concrete under ply just self level the area to bring you up level.
Never use pva
Nah. It’s timber frame under the marine ply .
Self level of you are bothered about height.   If it only a few mm the adhesive can deal with it. . .  Clear dust the SBR . And use a decent adhesive . Bal or Weber Weber are my preference.
