Russell griffiths Posted March 28, 2020 Posted March 28, 2020 Just doing some planning before I get a company to do a proper design does every extract point have to have have its own dedicated duct, or can two or more extract points run back to one duct and connect with a sort of Y junction. I have one area of ceiling that i that I would like to limit the amount of ducts in it, but this area then opens out into two separate rooms that would both have extract points in.
JFDIY Posted March 28, 2020 Posted March 28, 2020 Extracts usually have two ducts to cope with the flow and minimise noise. You might get away with three ducts onto two plenums , depend on the room use, size and expected flow rate Could you run a larger duct past the obstruction then have a separate manifold to serve those two rooms?
Dreadnaught Posted March 28, 2020 Posted March 28, 2020 I wonder if the concern about a y-junction connecting plenums for two rooms is the risk of cross noise transmission from room-to-room. And secondarily I wonder if it could make balancing the system more difficult if those two rooms were of markedly different size.
Russell griffiths Posted March 28, 2020 Author Posted March 28, 2020 Oh so two pipes for an extract, ooh that’s a bummer, means I have to get more ducts in than I thought originally
