In our hallway, there is annoying gap between the last beam and the poorly fitted plasterboard. It’s unsightly, and it also allows for drafts.
Space is limited. I thought of polyfilla first, but it’s difficult to get in, and sanding it later will be a problem too. The gaps are quite wide to caulk.
Suggestions welcome.
I suggest you chew toilet roll (admittedly can be hard to find these days but worth a look) and insert it in the gaps.
The saliva acts as a harding agent but retains flexibility.
pull out strip of PB fill behind with foam or what ever --refit PB when it still sof-pb should stick to it  -trim off foam as required ?
Edited by scottishjohn
20 minutes ago, MikeGrahamT21 said:
You've got/had woodworm! Suggest you get that checked out asap!
Had woodworm. I’ve treated all the beams. Should all be gone now. Fingers crossed.
I had thought of expanding foam. Removing the PB and then putting it back in after the expanding foam has been introduced is a good idea.
