We are just getting sorted to run the MVHR pipework and while I had defaulted to round outlets I saw this
And wondered if anybody had tried MVHR with slot outlets and if so what was the experience like?
I see they have veins within but it looks like they are a form non-return valve. I wonder how a linear diffuser could be selectively attenuated for the balancing an MVHR system, either supply or extract.
Edited by Dreadnaught
I was wondering that as well there must be a way and your link sort of helps but it looks like it might be tough none the less.
I think it is possible to locate the flow control away from the diffuser, presumably near the manifold, by using duct butterfly valves. This could be a solution.
I wonder if anyone has used duct valves for attenuation rather than diffusers.
  • 11 months later...
Resurrecting this old thread.
The MVHR extract vents in my kitchen either need to go though a steel beam or can be a linear diffuser in a wall without needing cut a hole in the beam.
But I am still not sure whether linear diffusers are good as extract terminals. I wonder, has anybody used a linear diffuser in their MCHR system?
@MikeSharp01, did you use one in the end?
