I am doing some room ceiling height fine tuning with my brickie team as the walls go up and can calculate wall-plate height very accurately. Above that the quote for the trusses gives the wall plate to peak height to the nearest mm. What I cannot judge is the thickness of the roof ridge tiling above the truss peak.
Is there an industry standard or this?
It will be a slate roof probably done in Nu-lok.
We had a problem with this as there was a height restriction to our build. As we had no gable walls it would be difficult to prove actual height but we did reduce the roof slope by a couple of degrees as the original bedroom ceilings proved a bit low. In practice (if I remember correctly) the height from top of truss to top of ridge tile was approx 100mm. But even if they got pedantic I believe you have a margin to the actual figure. As we used “angled” ridges rather than half round they fit more snuggly to the roof (and look better with slate IMO).
I think it was @AnonymousBosch that used Nu-lock.
Edited by joe90
