davidk Posted February 26, 2020 Share Posted February 26, 2020 The title says it all, extension planning is moving forward and we should have a full drawing package to allow us to go to tender this week. My main issue is that wall space is limited in the kitchen for radiators and our budget won’t stretch to wet UHF (retrofit or entirely new) and I also didn’t want the added expense of having to take the existing subfloor up to get the required depth. have been looking at hydronic plinth heaters for the kitchen (5.5m x 3.5m) and new utility room (2.4m x 2.6m) but finding any definitive reviews has been difficult. anyone any opinions on these or alternatives Cheers! Link to comment Share on other sites More sharing options...
joe90 Posted February 26, 2020 Share Posted February 26, 2020 I have fitted them for customers in the past and they have always liked them. Link to comment Share on other sites More sharing options...
MrMagic Posted February 26, 2020 Share Posted February 26, 2020 Yep, like them. Can be a tad noisy but not offensively loud. Pump out the heat. Link to comment Share on other sites More sharing options...
davidk Posted February 26, 2020 Author Share Posted February 26, 2020 Thanks @MrMagic and @joe90 for the quick replies, noise from the fans would definitely be my biggest concern but then they wouldn’t be on 24/7 and obviously heating the space sufficiently . Some more googling required. Link to comment Share on other sites More sharing options...
mm289 Posted February 26, 2020 Share Posted February 26, 2020 (edited) we have two wet underplinth heaters fitted in our kitchen to supplement a small rad. I quite like them, unobtrusive and with two fan speeds the slow speed is pretty quiet, you can tell its on just but not so that you have to speak louder or turn the telly up. For us they are also useful as we have an old farmhouse with solid walls and no dpc, so I like the idea of some area circulation being created under the kitchen cupboards to mitigate any dampness in the walls. Cheers, MM Edited February 26, 2020 by mm289 Link to comment Share on other sites More sharing options...
MrMagic Posted February 27, 2020 Share Posted February 27, 2020 It sounds like its worth investing in a two speed unit - I've got the Smiths space saver economy one, great unit but the lack of speed control I guess is whats contributing to the noise as it's permanently on 'high'. Really does pump out the heat tho. 1 Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 27, 2020 Share Posted February 27, 2020 9 hours ago, MrMagic said: It sounds like its worth investing in a two speed unit - I've got the Smiths space saver economy one, great unit but the lack of speed control I guess is whats contributing to the noise as it's permanently on 'high'. Really does pump out the heat tho. They’re definitely notable on the higher setting, so deffo go for the 2-speed. These also come with a remote control ( hard wired usually ) to save your back . Remember to factor in maintenance as the heat exchanger needs periodic vacuum / brush cleaning ( or possibly blowing through in situ with compressed air ) to stay efficient. As these suck air in down st floor level they are prone to dust / hair contamination which will eventually render them ineffective. Link to comment Share on other sites More sharing options...
davidk Posted February 27, 2020 Author Share Posted February 27, 2020 Gents thanks so much for the informative replies, I’ll definitely look into the 2 speed units. SAP calculations came in today so we’ve got our Part L compliance ok and revised SE and working drawings due by end of the week. Time getting close to go cap in hand to the mortgage company and out to tender!! ? Link to comment Share on other sites More sharing options...
