Reason I ask, is I drive past a stack of ~70mm PIR sheets left outside/ abandoned probably 6 yrs min at a guess. could it be used I wonder even trimming the obviously weathered edges off? obviously I can't just nab it & find out (I guess weight would simply tell you if water trapped within).. it is on s'one's property.
I can't think its made like a sponge, if its got to contain heat/ Id have though it be 1000's of tiny bubbles.. ie sealed. My builder's used some scrappy offcuts on my knock-through door (old stone cottage/ alot of pesky bits to fill) prety sure these been outside in elements.
Any ideas? cheers zoot.
It's what they call 'closed-cell' , which means that all the little bubbles are isolated from each other. That means it doesn't absorb water to any significant degree. I think there's a standard immersion test, where they hold a sample of the stuff under water for a period of time, and it has to absorb only a small fraction of its volume - something like 2% after a month's continuous immersion.
There may, however be an issue with UV light, as that does cause it to go a little crumbly.
When I buy it in it’s often cheaper to over order It’s often left outside for 12 months Always gets used or someone takes it at the end of the job
18 minutes ago, zoothorn said:
Ah thanks @Stewpot hadn't thought of its crumblyness. That might mean terrible cutting numnums.
If it's the foil lined stuff, it'll probably only be the edges that are affected - you should be able to trim it off, but then you'll end up with slightly undersized panels. Though that may not be a problem to you.
 Well this is what I was thinking. Yes its celotex I think, about 12  eight x four sheets stacked neatly in a pile. I'm gonna have to cut 8'x4' up anyway into 3 maybe 4 long strips (to insulate timber frame walls, studs ~400mm centres). If I could establish for definite only the edges might be n/g, & buy this lot off the hick.. I might well be able to save £500 who knows.
  • 11 months later...
On 12/01/2021 at 13:55, Seeoda said:
Some allege that it soaks water and reduces its effectiveness and hence should not be used as floor insulation.
PIR insulation should be above the DPM anyway.
Only time it's a concern in the floor is during concrete curing - wise to tape or stick some polythene over the top to protect the insulation for the ~24 hours of initial cure time.
