readiescards Posted November 7, 2016 Posted November 7, 2016 So SWMBO insists on heated towel rails. I've just seen you can get wet / water based towel rail radiators with optional extra built-in electric heater elements. These could be a useful dump for excess summer time PV. Are there any downsides to electric heater elements in wet towel rails? I note the sales leaflet says the valves need to be left fully open which makes me think each towel rail needs to be on its own manifold circuit controlled by a thermostat - so in Spring/Autumn the left fully open valve does not take lots of heat from the space heating system when its not needed.
ProDave Posted November 7, 2016 Posted November 7, 2016 Electric towel rails usually only have low power elements, so as a PV dump load are not that good.
Barney12 Posted November 8, 2016 Posted November 8, 2016 (edited) I fitted them in our last place. As @ProDave said they're only circa 400w so not much use as a PV dump. That was a standard radiator based oiled fired heating system. We only used the electric element to dry the towels in the summer (when the heating was of) and had them connected to a timer/boost switch that just heated the radiator for a predetermined time. One of these: https://www.tlc-direct.co.uk/Main_Index/Water_Heating_Index/Immersion_Heater_Timers_2/index.html This worked well for us as two of the bathrooms were not used that often. Edited November 8, 2016 by Barney12 1
Nickfromwales Posted November 8, 2016 Posted November 8, 2016 12 hours ago, Barney12 said: I fitted them in our last place. As @ProDave said they're only circa 400w so not much use as a PV dump. That was a standard radiator based oiled fired heating system. We only used the electric element to dry the towels in the summer (when the heating was of) and had them connected to a timer/boost switch that just heated the radiator for a predetermined time. One of these: https://www.tlc-direct.co.uk/Main_Index/Water_Heating_Index/Immersion_Heater_Timers_2/index.html This worked well for us as two of the bathrooms were not used that often. +1 on those electri saver units. I fit them when we do uvc's with a 20a switch paralleled as a master override . 2
