nod Posted November 29, 2019 Posted November 29, 2019 Now that the nights and days are colder we are using the UFH This time last year we had just moved into a empty cold house so we left it on the factory settings and went with the flo We would be interested to what temperature you guys are running yours at Or weather you are timing or adjusting manually through the day
Declan52 Posted November 29, 2019 Posted November 29, 2019 Do you mean the temperature settings for each room on the stat or the water temperature going into the ufh system??
Triassic Posted November 29, 2019 Posted November 29, 2019 (edited) Isn't the UFH water inlet temperature dependent upon the required room temperature and established by trial and error? Edited November 29, 2019 by Triassic
mvincentd Posted December 6, 2019 Posted December 6, 2019 The minimum temp I can set on the stat that is on the manifold controlling flow temp is 30 so thats what i've had it at. Only been using ufh for the last week though so i'm no expert. It's been enough so far but for some reason tonight i'm cold so am upping to 35 in hope it will speed the lift in room temp.
Temp Posted December 7, 2019 Posted December 7, 2019 The loop flow temperature sets the maximum power output. If you set it too low the room temperature might not reach the temperature set on the stat when it's very cold outside. So monitor the set and actual room temperatures in January.
