Temp Posted November 22, 2019 Posted November 22, 2019 (edited) Is it ok to run Hep2O plastic pipe into compression fittings like this designed for copper? https://www.toolstation.com/pressure-reducing-valve-and-gauge/p11827 With pipe inserts obviously. I know there is a pressure reducer with 1/2" brass ports and 1/2" brass to HEP20 adaptors. Edited November 22, 2019 by Temp
joe90 Posted November 22, 2019 Posted November 22, 2019 I prefer to convert to copper for compression fittings, also I did not get on with the reducer insert (22 to 15mm) that came with this PRV , it leaked despite several attempts (yes I used one of these in my build).
PeterW Posted November 22, 2019 Posted November 22, 2019 Yes although I tend to use a copper stub and then use a straight connector or an elbow
Temp Posted November 22, 2019 Author Posted November 22, 2019 Thanks. I'm adding a pressure reducer into an existing plastic pipe so think I'll go with this one.. https://www.toolstation.com/pressure-reducing-valve/p94502 And a pair of adaptors.. https://www.toolstation.com/hep2o-male-adaptor-brass-socket/p54535
joe90 Posted November 22, 2019 Posted November 22, 2019 6 minutes ago, Temp said: Thanks. I'm adding a pressure reducer into an existing plastic pipe so think I'll go with this one.. https://www.toolstation.com/pressure-reducing-valve/p94502 And a pair of adaptors.. https://www.toolstation.com/hep2o-male-adaptor-brass-socket/p54535 am I missing something, what pressure does it reduce too.?? Does not say, no gauge either. ?
Temp Posted November 22, 2019 Author Posted November 22, 2019 Normally they are preset to 3bar but I guess I should check. 1
Temp Posted November 23, 2019 Author Posted November 23, 2019 20 hours ago, Temp said: Thanks. I'm adding a pressure reducer into an existing plastic pipe so think I'll go with this one.. https://www.toolstation.com/pressure-reducing-valve/p94502 And a pair of adaptors.. https://www.toolstation.com/hep2o-male-adaptor-brass-socket/p54535 In the end I remembered that the thread on a 15mm compression fittings was 1/2" BSP so a much better option was a pressure reducer with compression fittings (removed) and a pair of these tap adaptors.. https://www.toolstation.com/jg-speedfit-straight-tap-connector/p13693
ProDave Posted November 23, 2019 Posted November 23, 2019 I will be interested how you get on with that. A tap connector expects a nice crisp flat shoulder and seals with a fibre washer, not the tapered profile where the olive would go.
Temp Posted November 24, 2019 Author Posted November 24, 2019 Yes was a bit concerned but it looks fine on the Honeywell regulator. The tap connector I have also came with rubber washers.
