Russell griffiths Posted October 20, 2019 Share Posted October 20, 2019 Trying to find if anybody local ish, has any spare blocks im in Cirencester Gloucestershire and looking for 4 blocks if anybody has them. Bit of a long shot cheers russ. Link to comment Share on other sites More sharing options...
Triassic Posted October 20, 2019 Share Posted October 20, 2019 Sorry I don’t have any Nudura blocks, I do have some Amvic blocks and corners left (as a result of a last minute design change!) Link to comment Share on other sites More sharing options...
scottishjohn Posted October 20, 2019 Share Posted October 20, 2019 (edited) 1 hour ago, Triassic said: Sorry I don’t have any Nudura blocks, I do have some Amvic blocks and corners left (as a result of a last minute design change!) worth posting the size of them to russell --should easy enough for a man of his capabilites and determination to use them Edited October 20, 2019 by scottishjohn Link to comment Share on other sites More sharing options...
Sandybay Posted October 23, 2019 Share Posted October 23, 2019 ICF versus wooden frame icynene filled. Was set on ICF build, but builder quote to w and w stage is high, and not sure on completion cost, have a better idea of costing on a block built timber frame icynene sprayed build, are the two a comparable products? Thanks. Link to comment Share on other sites More sharing options...
scottishjohn Posted October 23, 2019 Share Posted October 23, 2019 12 hours ago, Sandybay said: ICF versus wooden frame icynene filled. Was set on ICF build, but builder quote to w and w stage is high, and not sure on completion cost, have a better idea of costing on a block built timber frame icynene sprayed build, are the two a comparable products? Thanks. how much of a difference- and how have you got an accurate price this quick ?was only yeterday ,.so they cannot have had your plans to give a proper quote on-and thrta is the only way to do a comparison nd can you elaborate on what you mean by "w and w" means -- if its what ithink --just a diffewrent spec of windows and ooors could be 15K of a difference anyway--you need cspecfic detaiuls of what is being used --Iam guessing your wood frame guesstimate is basic dglazing and maybe ICF is better quality or triple glazing there are guys on here who have ppaid 40k just for windows and doors i expect basic TF to be cheaper than icf --but all depending on spec could 10% only for what iwould consider a better build spec -send them plans and get detailed spec on both and if you got nudura quote that will be one of the most expensive types of ICF --more researching required Link to comment Share on other sites More sharing options...
scottishjohn Posted October 23, 2019 Share Posted October 23, 2019 12 hours ago, Sandybay said: ICF versus wooden frame icynene filled. Was set on ICF build, but builder quote to w and w stage is high, and not sure on completion cost, have a better idea of costing on a block built timber frame icynene sprayed build, are the two a comparable products? Thanks. are you doing any of the build or are you going for turn key package ? spray iceyen is expensive compared to YOU getting insualtion type of your chice and fitting it --for a bulder it works out about the same --but he don,t have to spend hours fitting slabs or cutting pir boards to make them fit iF YOU DOING IT YOU WIL SAVE ALOT OVER ICENENE SPRAY -- it is the labour parts of the build where you can save big ICF the majority of the insulation is in the build process of outer skin and roofing choice -10sqm for concrete tiles or £100+ for exotic slates ,so many choices to make to get the finished price even for w+w stage and outer skin --rendered or facibnf brick or wood --all different prices and labour content -something else you can do yourrself Link to comment Share on other sites More sharing options...
Russell griffiths Posted October 23, 2019 Author Share Posted October 23, 2019 12 hours ago, Sandybay said: ICF versus wooden frame icynene filled. Was set on ICF build, but builder quote to w and w stage is high, and not sure on completion cost, have a better idea of costing on a block built timber frame icynene sprayed build, are the two a comparable products? Thanks. No, like chalk and cheese. Link to comment Share on other sites More sharing options...
