Received a drawing on one of my UFH quotes and thought I could probably do something a little more suitable for us,  so see below.
UFH 1 is the companies drawing.
I have done two versions, one as a Serpentine, letting LoopCAD do most of the design.   Second is a Spiral for most loops, drawn freehand.  Both my ones keep the loops a little shorter and I think better zoned.
Anyone care to comment and make recommendations?
UHF_1.PDF Serpentine.PDF spiral.PDF
Edited by BMcN
  • 1 month later...
Spiral is better as you have drawn it
UFH supplier is smoking crack...
Minor tweak to yours - don’t go under the WC pan in the shower room.
  • Haha 1
I went for serpentine, just easier to set out.
In a low energy house running at a low temperature I really don't think you will notice any difference in performance.
Thanks @ProDave@PeterW.
I might have an attempt at the spiral and see how difficult it in.  Maybe for the loops that are not very square I'll stick to the serpentine one.
As a slight aside but still on topic, my design showed all pipes going through doorways which crowded them, instead I ran pipes through some internal block walls to use less pipe and less pipes in doorways which could weaken the screed (IMO). I drilled 25mm holes and ran UFH pipes inside overflow pipe when in the wall, 300mm lengths.
Just watch for the size of the last loop - its a bulb shape and needs around 250/300mm to do the loop.
Thanks @joe90, yes I will probably do the same then, the two main partitions are load bearing so concrete drawf walls under anyway so going through a doorway here is of no benefit anyway.
Noted thanks @PeterW
