willbish Posted August 17, 2019 Posted August 17, 2019 Has anyone found a neat way of holding lead flashing when placing into EPS? Ill have a render drip bead hanging over that will provide some support, but I wont fix through the lead. I suspect I'm probably looking at some grab adhesive or more low ex foam.
nod Posted August 17, 2019 Posted August 17, 2019 The majority that I render are simply pushed in place and the render bead does the rest I would stick them in place with stickall Then use basecoat to stick a render bead over Just lapping10 mil onto the lead
Russell griffiths Posted August 17, 2019 Posted August 17, 2019 Have you seen the spring loaded clips that hold lead into a brick join. You could probably cut a neat chase and use the clips then use a ct1 type sealer to finish off.
willbish Posted August 17, 2019 Author Posted August 17, 2019 Thanks @nod thought the render bead would probably do most of the work @Russell griffiths yes ive' seen them, got a packet ready for the chimney lead work. I reckon banging them into EPS will just squash the foam and not create a good wedge but Ill give it a try.
nod Posted August 17, 2019 Posted August 17, 2019 4 hours ago, willbish said: Thanks @nod thought the render bead would probably do most of the work @Russell griffiths yes ive' seen them, got a packet ready for the chimney lead work. I reckon banging them into EPS will just squash the foam and not create a good wedge but Ill give it a try. You’re welcome It’s quote surprising how strong a rendered bead over lead is and nothing will get through pictured below is a rush job on a roof we’re there is little holing the lead in place One the render has set its lifted up so that the rolled steel roof can be installed All done now No cracked render No where for the water to get in
magnethead Posted August 23, 2019 Posted August 23, 2019 (edited) Is it important to cut into the EPS at an angle above the stopbead? like below I imagine this would be a pain if your stopbead is running up the wall at an angle, i'll be facing the same problem soon enough. It looks like there is some fixing joining the stopbead back to the concrete/block Edited August 23, 2019 by magnethead
willbish Posted August 23, 2019 Author Posted August 23, 2019 1 hour ago, magnethead said: Is it important to cut into the EPS at an angle above the stopbead? A slight angle probably make won't much difference or improvement to a level chase. Imagine lead flashing going into a mortar joint between brick. That would be level and works just fine.
magnethead Posted January 24, 2020 Posted January 24, 2020 just to add my 2 cents, this is how I decided to go. This flashing is coming down at an angle of 15degress. one mistake I made, was not covering the heads of the 150mm concrete screws with CT1/tec7 If water ever got behind the stop bead and travelled down the lead, It could get in behind the head of the screw...damn (I CT1/tec7 the lip on the lead to the foam all the way up)... I then sprayed in some Soundal foam filler to fill the gap (20mm x 20mm) The stop bead was eventually put on, covering the lead by about 20mm
