I want to make, what I think should be a simple app for my phone.
All I want it to do is take a picture every time I move a set distance, store the picture and attach the appropriate location to it.
How does one go about this.  I have looked at a few tutorials, but I think I am missing something very basic.
It would be nice if I could 'do the work' on my PC, rather than fiddle on the phone.
Anyone done this?
You need the android SDK, you can then work in JAVA, it is simple once you get your head around the way Android wants things done - page based is simplest but you can write background apps if you want. Where exactly are you stuck?
Right at the very beginning.
I tried an online development package, got as far as giving it a title, then I could find nothing.  All it seemed to want to do was make a pretty GUI.
Is Android SDK a program that runs in Windows?
Never done any work in Java, I struggle with a bit of Python to be honest.
I think there is a blocky version you can use.
Bingo - that is the base case you create the GUI as you have to be able start / stop the app but once started you can leave it running on the phone or suspend it when the window is not visible - close it and it stops.
I have downloaded and installed Andoid Studio, that seems to have SDK in it.
That makes sense, but how to I add in things like the camera, GPS and then, and this is probably the easy bit, make some code to do what I want it to do.
  • 3 months later...
 Before writing your own app, I'd first check no one already has. There's loads of apps to turn an old phone into a dashcam, most support motion activated recording so some might have the every N distance feature you need e.g.
https://www.howtogeek.com/270340/how-to-turn-an-old-smartphone-into-a-dash-cam-for-your-car/
If that wasn't satisfactory, then I'd look at workflow automation apps like Tasker and Locale, see if they have plugins for movement trigger and taking a photo
https://play.google.com/store/apps/details?id=com.twofortyfouram.locale&hl=en_GB
https://play.google.com/store/apps/details?id=net.dinglisch.android.taskerm&hl=en_GB
https://play.google.com/store/apps/details?id=com.kanetik.movement_detection&hl=en_GB
If none of those work out, I'd start digging around in the Java/kotlin SDK.
I’ve had to create an Android app for my masters. I used eclipse. Eclipse is a free professional interactive development environment. It has full debug capability and an android emulator. That means you can run your code and it launches a phone app on your computer screen For testing and interacting with.
you can download eclipse here: https://www.eclipse.org/downloads/packages/release/oxygen/1a/eclipse-ide-java-developers.
developers tend to use github to (https://github.com/) store and share projects. From here you can download source code. It may be that you can find something close to your needs and modify it to your specification.
