epsilonGreedy Posted August 4, 2019 Posted August 4, 2019 I think there is a minimum cover depth for foul water drains and where that depth is not achieved a concrete capping is required. Does anything similar apply to rainwater roof drainage across a garden or patio?
PeterW Posted August 4, 2019 Posted August 4, 2019 Any 110mm pipe that is going to be under 300mm deep really needs to be concrete capped, even if it is only to protect it when you landscape over as a whacker plate will stick MoT1 through UPVC pipe with ease 1
epsilonGreedy Posted August 4, 2019 Author Posted August 4, 2019 19 minutes ago, PeterW said: Any 110mm pipe that is going to be under 300mm deep really needs to be concrete capped, even if it is only to protect it when you landscape over as a whacker plate will stick MoT1 through UPVC pipe with ease Thanks I can work with 300mm, in fact in the absence of any regulations I would have self imposed a minimum depth equivalent to a vigorous plunge of a garden fork. Some other reading got me thinking the minimum cover was 600mm.
Vijay Posted August 4, 2019 Posted August 4, 2019 I had the same issue. On here it says 600 http://www.pavingexpert.com/drain02.htm my BCO wanted concrete over it but mine was on the front drive, so maybe different depending on pedestrian or vehicle traffic? 1
andyscotland Posted August 4, 2019 Posted August 4, 2019 I had a similar thing, pedestrian traffic only, and ended up speaking to Marley technical. They said anything above 600mm should have a concrete cap (slabs or in situ concrete) over the top. 75mm gravel between crown of pipe and base of concrete. 1
Jeremy Harris Posted August 5, 2019 Posted August 5, 2019 Our neighbours foul drain pipe is visible. It's a clay pipe that can be seen where it crosses the stream bed. Not sure when it was put in, probably 50 years or so ago when mains drainage came to the village. I doubt it complied with any regulations, even when it was first laid.
Ed Davies Posted August 5, 2019 Posted August 5, 2019 I chopped a chunk out of the top of the clay drain pipe from the kitchen sink in the (I assume 1970s or 80s) extension of the house I'm renting with a hover mower. I'd noticed it just poking out of the ground and avoided it before but the grass was a bit long and I forgot.
