Peter3 Posted July 20, 2019 Share Posted July 20, 2019 Hello. Stairs and upstairs landings creaking loudly underfoot. House built in mid 70's, wooden stairs and landings dried out. Could anyone please advise of a method or a product which could deal with this problem, without having to tear the place apart ? I will take up the stair carpet and underlay if I have to. Thank you, Pete. Link to comment Share on other sites More sharing options...
Miek Posted July 20, 2019 Share Posted July 20, 2019 If the stairs are made the traditional way with wedges for the treads and risers it might be worth getting under them with a hammer and seeing if you can knock them in a bit. Link to comment Share on other sites More sharing options...
Peter3 Posted July 20, 2019 Author Share Posted July 20, 2019 (edited) Thanks, but unfortunately they are not made the traditional way. I can only get at six of the treads from underneath and nothing else. Edited July 20, 2019 by Peter3 Link to comment Share on other sites More sharing options...
Peter3 Posted July 28, 2019 Author Share Posted July 28, 2019 Anyone please ? Link to comment Share on other sites More sharing options...
Ferdinand Posted July 28, 2019 Share Posted July 28, 2019 (edited) I think you are not getting advice because no one knows. Suspecting that the way to fix this is going to be to replace the whole thing with a custom designed replacement from somewhere like Pears Stairs or Stairbox. I have no idea how to fit that in to an existing space but stairs seem to get installed late on in self builds. I think that if you can bottom the dimensions and how it fits the jigsaw, then the actual cost could be modest (Ish), as they are not hugely expensive. That is, low thousands not high hundreds. Lots of design work though, and you will need a demon checking partner, cos if it won’t fit you could be seriously banjaxed. That may be a better option than several days of Joiner, though I would explore both. Can you get hold of some docs with the original design or dimensions? Ferdinand Edited July 28, 2019 by Ferdinand Link to comment Share on other sites More sharing options...
ToughButterCup Posted July 28, 2019 Share Posted July 28, 2019 On 20/07/2019 at 23:13, Peter3 said: [...]. I can only get at six of the treads from underneath and nothing else. Having just built some temporary stairs - one tread of which creaked - I venture to suggest that you are going to have to expose the hidden under-stair area. Then the answer is likely to be contained in one or more of these videos Link to comment Share on other sites More sharing options...
Simplysimon Posted July 28, 2019 Share Posted July 28, 2019 picture would help 'as not made the traditional way' need to see what you mean Link to comment Share on other sites More sharing options...
Peter3 Posted July 28, 2019 Author Share Posted July 28, 2019 Many thanks to Ferdinand and SimplySimon for the replies. Many thanks to AnonymousBosch for the time and trouble taken in linking the video's. Link to comment Share on other sites More sharing options...
