jack Posted February 13, 2017 Posted February 13, 2017 8 minutes ago, lizzie said: ... and we can buy fittings from them or not as we choose. Sounds good. Just make sure that the lights they specify are going to be generic enough that you'll be able to buy them - or something similar - directly. The brief experience I had involved the specification of a single light (well, a cluster of light types) that would have cost several thousand pounds for a single room, and had no obvious affordable alternative. 1
lizzie Posted February 13, 2017 Posted February 13, 2017 6 hours ago, jack said: Sounds good. Just make sure that the lights they specify are going to be generic enough that you'll be able to buy them - or something similar - directly. The brief experience I had involved the specification of a single light (well, a cluster of light types) that would have cost several thousand pounds for a single room, and had no obvious affordable alternative. Thank you for the tip Jack! Noted. 1
TheMitchells Posted February 13, 2017 Posted February 13, 2017 (edited) On 20/09/2016 at 14:33, Bitpipe said: We have a bulk head running through each bathroom and decided to line either side with appropriate temp white LED strips through a diffuser - has worked really well and we decided to treat the rooms in room the same, building a small bulkhead at the apex vs a deeper one to take recessed lights. Our ceiling LEDs are also on a pivot which allows them to wash the wall, rather then straight down. @Bitpipe any chance of a photo to show what you mean, please. Edited February 13, 2017 by TheMitchells
